Street Intersections in CD3
So, I finally figured out where the plain' ole modern day line in the middle streets are in CD3 (#slowestCCmapperever), but I discovered that where two roads cross each other (as they often do) it...well it needs an intersection because the breaks in the yellow lines and crude overlays of road just don't work. But I can't seem to find an intersection.
Does one exist already? Is there a symbol set I needs must purchase? Can someone gimme a hand here?
Thanks all.
Thanks all.
What about using hallways from Dungeon Designer to make roads ? Just leave off the end pieces, its a selection in the road popup.
Yup, 'Add Corridor' check 'no end wall'.
Have a city map open. Click on the DD icon at the top of CC3. Select 'Add Corridor'. Grass foreground, dirt background, no wall.
Drawing below.
