Second Post! New Problem!
So...I have gotten to the point where I want to add some text to my map. Following the instructions in the manual, I have tried to add some "text on a curve". Everything comes out all right till the very end. I have the "remove Guide line" box check off, but the guidelines keep showing up. The only difference is that they now are white!
What did I do now.......?
T-68
T-68
Text showed up...again with the white line through it.
Hit redraw, everything I just did disappeared (text and line)!
T-68
Is the sheet for what you are drawing on listed above the "Text" sheet.
Sheet order is real important and if they are not in the right order, what you have just done will disappear underneath the sheet you placed it on.
I am not at home so I had to grab a graphic off of the internet. That is something that I have done before, I would be working on mountains and I would decide that a lake would be good here, and then changed the sheet and layer setting to put a lake down, and go right back to building mountain ranges without changing the sheet and layer setting back. Very frustrating. LoL! ;-)
Hope this helps.
Hide sheets one at a time until you find your curved text. Then do a move to sheet selecting your curved text, and move it to the same sheet as the rest of your text.
And thanks for trying to help me out guys!
T-68
