Fonts in CC3+
Could someone please tell me, where does CC3+ store the information about user added (with "More Fonts" button) fonts? I want to clean up that list, remove those without proper cyrillic support.
  • edited April 2016
    I'm not quite sure what you're asking, but I will tell you what I know, perhaps it will answer your question.
    Cc3 has a number of fonts already stored in the program. I'm not sure where, but there MAY be a fonts folder in the program data. I'm not positive, so please don't quite me on that.
    However, cc3 (+) can also access any font you have installed on your computer. When you open your cc3 program, down the right side of your view window there are a series of buttons. The two bottom buttons are your text buttons. The left button allows you to make text that you put on your map. The RIGHT button is how you set the parameters for your text.
    If you click on that right button you can scroll through the fonts cc3 already uses. But if you don't want those fonts, there is a lo g button at the bottom that says more fonts.
    Clicking on the more fonts button will bring up another window, and it will list any font you have stored on your computer. It will also have the vector fonts that came with cc3, but you don't want to use those, there's a problem with them and they cause cc3 (+) to crash.
    I don't know if this answers your question... But it may give you directions on whether to look.
  • Sorry for the typos... Stupid autocorrect!!!
  • Blackadder23Blackadder23 Traveler
    edited April 2016
    They're in the ProgramData/Profantasy/CC3Plus/Fonts folder, at least on my computer.
    (Note that ProgramData is a "hidden" folder by default. You may have to change some settings in order to see it.)
    The font references are stored in each individual map, these are just references to system fonts. Note that these are inherited from the template used when creating a new map, so you could also edit a template to remove a font reference, and new maps from this template hereafter will inherit only the fonts specified in it.
    The 'More fonts' button brings up the list of all fonts installed on your system, to clean up this list you need to uninstall the font from the operating system.
  • How do you un-hide the hidden folders?
    I cannot find the PDF tutorials that come with each annual update.
    The pdfs should be in Profantasy\CC3Plus\Annuals\issue folder
  • edited April 2016
    This is what I get. I know they have to more folders because I can access them from the CC3+ software to get to bitmaps, symbols and more. But, they do not even show up when I run a search command on my computer for PDF files.
  • edited April 2016
    Posted By: MonsenThe font references are stored in each individual map, these are just references to system fonts. Note that these are inherited from the template used when creating a new map, so you could also edit a template to remove a font reference, and new maps from this template hereafter will inherit only the fonts specified in it.
    Thank you, Monsen, for the explanation! Does it mean that all fonts, that I've added with "More Fonts" button to my current map, will be with it forever?
    I've been "working" on a one single map two or more years already, so the thing about templates and inheritance wasn't obvious for me. New map and the font list has no additional fonts.
    Thank you everyone for your help!
    Posted By: CharlesWayneRobinsonHow do you un-hide the hidden folders?
    I'm not sure, because my windows 8.1 is in russian, but it should be this way: open your win files browser => go to "View" panel => click "Parametrs" button (or Options) => go to the 2nd tab and search for hide|unhide checkbox.
    And here is the list I've been so concerned about. No "delete" button. :(
    edited April 2016
    If you have Windows 7, select the "Organize" button, then "Folder and Search Options", then "View", and finally "Show Hidden Files, Folders, and Drives". The ProgramData folder should appear directly below ProgramFiles (x86).
    If you have Windows 8 or 10, I have no idea.
  • Thanks Blackadder23,
    I still cannot get anything to pop up and I am using Windows 7.
    Frustrating. LoL!
  • Jay_NOLAJay_NOLA Traveler
    You need to do several things in Windows 7 to access the Fonts and check to see if they are installed correctly.
    See this thread and read the posts I made as I covered most of the issues people have with fonts and covered it them in detail with correct fixes.
    http://forum.profantasy.com/comments.php?DiscussionID=4325&page=1#Item_7
    CC3Plus puts files a copy of any fonts it installs or ties to in a ProgramData folder and in the Programs folder it doesn't put all the files that are kept in the separate ProgramData folder to deal with Windows permission issues.
    CC3 by default puts everything in the Programs folder and CC3 and doesn't split files it uses up into 2 separate locations and is known to cause font install problems on Vista and up.
    I'm suspecting that you may have some duplicate fonts installed and some font registry problem caused by this which could be an issue with not being able to delete or add them.
    Posted By: CharlesWayneRobinsonI cannot find the PDF tutorials that come with each annual update.
    An easy way to get to the folder is to open an explorer window, click into the address bar (remove everything there already) and type in %allusersprofile%/ProFantasy/CC3Plus then hit enter (This assumes you have installed CC3+ to the default folders. Note that this trick can also be used in the open/save dialog boxes of programs.
    edited April 2016
    Posted By: kilma.ard.venomAnd here is the list I've been so concerned about. No "delete" button. :(
    Yea, that dialog doesn't have a delete button. To get rid of unwanted font, you need to execute the FONTPURGE command (Just type it on CC3's command line and hit enter. This command purges all unused fonts from your map. You can then add back any you wish to keep. (Note that it won't touch fonts that are in use in your map).
    Do note that the fonts in this list are only references to system fonts, purging them will not free up space or resources, the only benefit is to get a cleaner list. Fonts are not embedded in the map.
  • Posted By: CharlesWayneRobinsonThanks Blackadder23,
    Frustrating. LoL!
    If you are running Windows 7 with CC3+ in the default location, here is how to find the Annual folders:
  • Posted By: Monsen
    An easy way to get to the folder is to open an explorer window, click into the address bar (remove everything there already) and type in%allusersprofile%/ProFantasy/CC3Plusthen hit enter (This assumes you have installed CC3+ to the default folders. Note that this trick can also be used in the open/save dialog boxes of programs.
    Thanks Monsen! As usual, you are such a great help and a fountain of knowledge!
  • Thanks Blackadder23!
    A picture is worth a thousand words, I see where I was messing up.
  • Posted By: Monsenthe only benefit is to get a cleaner list
    Thank you very much! That is exactly what I need.
