Importing Bmp files
I have created several new structures using corel draw and have impoted them into CC3. I am able to find my images and move them around, scale and do everything I can with CC3 images on the map, but I can not get them to stick to the map.
Am I missing a step or doing domething wrong?
    Make sure you place them on an appropriate sheet. If you just use them directly as png images, they are inserted on the current sheet when you place them. If this sheet is low on the drawing order, they might end up below other objects (They will show on top until you do a redraw).
    If you made a proper symbol catalog for them, make sure you set an appropriate sheet for them in the catalog settings.
