Working with the clipboard
So I have made my map of Ehmeral, and in it I added the northern tip of Tuschana, my last continent in my world of Larysia. I wanted to show the size of the Great Tuschan Sea, which is between Ehmeral and Tuschana.
I am now ready to draw the last continental map, and I want to begin with the northern tips that's on my previous map. I keep hearing about copying to the clipboard and pasting in a new map, but I don't understand what that means in cc3+. Where is the clipboard? How do I do this?
There are a few differences in CC3(+). After activating the Copy command, you will need to look at the prompts on the command line.
You will be asked to select the entitie(s) you want to copy (then Right click do it)
You will then be asked to choose the origin of the copy. I personally just keep the default of (0,0) by hitting enter, but you can also enter other coordinates or just pick a point on you map. (The origin is the point where your copied object will hang off of the cursor crosshairs when you paste.)
Your objects are now in the clipboard ready to be pasted into another place on the map or into a new map.
The quickest and easiest way to learn the difference, honestly, is to open the CC3+ online help (click Help>Help from the menu bar) and then find copy to clipboard in the Index.
Cheers,
I then just hit the redraw, and I had my whole land mass. A bit involved, like I said... but I got what I needed.
