Curved text
Hello,
Me again with yet another newbie question ! Is there a way to have a text element be written along a curve rather than a straight line ? I looked around in the text options but I couldn't find anything.
Thanks in advance,
o>
Sv.
Thanks in advance,
o>
Sv.
And I guess I should start right clicking everything. So many treasures hidden just a right click away !
https://secure.profantasy.com/products/tome.asp (I hope this link is OK). I use it all the time.
I love your interest in CC#, though, and I learn quite a bit from your questions, as well as the answers that follow. Love to see your work, Quenten
And I really like CC, it's really good at what it's meant to do and is helping me a lot for the project I'm working on. You can tell a lot of thought and experience have been put into making this software.
I've started my current map over several times now, but I hope to post some screenshots soon(tm) !
I have another question regarding curved text, and the Tome of Ultimate Mapping wasn't of any help, so I guess it's just me being terrible at CC3+.
When I draw a curve that goes downards first then upwards and use it to draw curved text, the text is upside-down (see attached image) ... Is there any way to change that ?
If you must use an ARC to create the curve you are trying to run the text from, you can do the following:
Draw your arc, it does not matter what direction. Then use the line to path command on the command line ( LTP2 ). Click any end of the arc. Then do Text along Curve. This will place the text in the direction (left to right) and desired location (top, middle or bottom).
I'd recommend using a smooth poly for curves as you can directly determine the direction by the start point you use. You can draw an arc first as a guide, then do a smooth poly and follow the contour in the direction you want.
I'll give Dkarr's solution a go when I can, but it sounds like a solid lead. Thanks.
