FRIA Install Problem
Recently got a used copy of the Forgotten Realms Atlas. The disk appears good and the files all seem good, but I can't get the setup to run. I've tried on two different Win 7 machines (one premium, one professional). I've tried running as administrator. Tried various compatibility settings.
The GUI doesn't even open up. I get a couple of screen flashes, and the task manager shows that setup.exe is running, but nothing ever comes up.
Ideas?
Note, I don't need the viewer as I have CC2, but from my understanding, without the FRIA installed, the updates won't update the maps right?
Ideas?
I have it installed on a Windows 7 Professional 32 bit machine and I used XP compatibility mode with requires additional privilages checked as I recall.
The FRIA had some updates patches for it which just updated maps and lots of additional maps. You can still download the patch files from wayback machines versions of Wizard's site. A CC3 version of the new symbols were also done.
Your install ought to go:
1.) FRIA
2.) Patches/Updates
3.) CC3 version of symbols.
After that you need to check your font folder and your registry entries for the new fonts the FROA installs. They don't install correctly on Vista and up.
Also some of the forgotten Realms fonts even when installed correctly (in font folder & rgistry entry is correct) because of changes Microsoft made to how font Metadata is handled that started with XP.
Since you have a machine with Windows 7 Professional do you have the XP Virtual mode set up on it. If you do see if you can can install it iin the XP virtual system.
My Windows 7 laptop has the FRIA installed in Windows 7 and also in XP Virtual Mode. (The XP Virtual Machine Mode is so I can use it with CC2 which only works in XP Virtual Machine Mode.)
Using a 64-bit machine. Tried disabling anti-virus (Sophos) via services, services stopped, but did not help. SETUP.EXE*32 shows up in the Task Manager, but nothing appears graphically (same behavior as before). I do have dual graphic cards, onboard Intel and NVIDIA, could that be an issue? I've used both via right mouse button "Run with graphics processor..." but still same behavior.
I'll live without the fonts, and mentioned, I can get the maps from the original, but not from the updates, since they are all in cab files or such and not in the open like with the FRIA. Is there a way to get the maps out of the archives/cabs without running the installer? (A legal way that is.)
You mention that CC2 doesn't run on Win 7... But I've been running it on this and my previous laptop. VERY limited use (turning on/off layers, pan/zoom, export mostly), but just tried to create a new map last night and could not... Was going to start a thread asking about that, and will if you're not sure.
CC2 on Windows 7 like you said has very limited use and you can't use it properly on Windows 7. I have it installed in both Windows 7 and in XP Virtual mode and I just use the Windows 7 install to do some things, as it isn't full comparable.
For more info on XP Virtual mode see:
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
You need to download and install it.
XP Virtual Mode isn't installed by default and you need to install it separately.
Basically it sets up a a separate Virtual PC on your Windows 7 system that uses Windows XP.
If you have it installed you'll see Windows Virtual PC in your start programs list.
The fonts as you said aren't a big deal but you do want to check them anyway as some of them do work, but Windows screws up the install. The font install problems are common common with Vista and up
See this thread and the posts I made in it
http://forum.profantasy.com/comments.php?DiscussionID=4325
Going to the install not working I had to use compatibility mode XP Service Pack 2 I think to get the FRIA to install on my Windows 7 laptop and I had to turn off UAC and my antivirus program.
Check to see if you have Microsoft .NET Frame work 1.1 installed and SP 1 for it. If not install them.
https://www.microsoft.com/en-us/download/details.aspx?id=26
https://www.microsoft.com/en-us/download/details.aspx?id=33
Some people reported needing to have DOSBox installed to get it to run on some other forums.
You'll also need to install another fix from Microsoft as I recall for the Help files to work right as they won't display in Windows 7.
The only thing that I can think of is that your admin setting could be an issue. This is a known problem with the FRIA, but since you have tried as an admin I don't have a solution.
Some people on some other forums reported the same problem you are having and they were using Vista. Others didn't have the problem with the same version of Windows.
There is the possibility that it got shifted off screen. Hold in your Windows key and type P. Make sure that 'PC Screen Only' is selected.
Shessar, yea, it shows in the task manager, but I couldn't alt-tab to it. I'll try the win-P tomorrow.
Thanks all
https://www.microsoft.com/en-us/download/details.aspx?id=91
When you click the download button you'll see a page with a version for 32-bit Windows 7 and one for 64 bit Windows 7, so you only install the one based on if you version of Windows 7 you are using
Also if you have any question about XP Virtual mode just ask. XP mode does run in Windows 7 so you're not having to reboot the system or anything to use it. Virtual Mode open up in a separate Windows.
The FRA installed just fine on the XP virtual machine. But now I can not install Update 1 or 2. Update 3 installs apparently fine, but 1 & 2 ask for the disk in the
The virtual machine sees the
Maybe if I make an .iso file of the disk and create a virtual drive?
Check to see if you have these FCW files in the FR Atlas Maps folder with the file dates I indicated next to the names if you do then you have all the updates installed.
30005 Aru (9-12-2001)
update2 (2-21-2000)
5450 Yulash (10-6-1999)
If you have all of them you don't need to worry about making an .iso file and the rest of the troubleshooting.
I didn't have the updates to installing issue installing it in XP mode.
It might have something to do with the type/model of CD-DVD drive you have. I had a similar issue with an old game I had installed and the issue is the CD-DVD drive I have. So I couldn't install it. (More on this later in my post.)
You can try making an .iso file it might work, but I'm not sure.
When you went to install the updates you did copy them into a XP mode document folder or into a folder you could access into that is in XP mode?
Glad to hear you got it to install into XP Mode.
XP Mode is also good to have if you want to have your old CC2 stuff working as you can install it.
One other thing if you do opt to install CC2 into XP mode so you can use your CC2 fully and any aexpansions for it you'll need to uninstall the FRIA from XP mode and reinstall it after you install CC2 for the FRIA symbols to install into CC2
Also, given what you said about the CD-DVD drive issue I'm suspecting that the reason the FRIA wasn't install in Windows 7 was connected to the CD-DVD drive. Some older CD-DVD software programs have trouble installing in Windows 7I discovered because of CD-DVD drive issues that can't be easily fixed. Older software disk don't like CD-DVD drives that can also burn CD's & DVDs.
So, I have 30005 Aru map with the mentioned date. I do not have update2, and my 5450 Yulash has a date of 8/19/99. So I'm thinking update 3 is not cumulative.
As for installing the updates, I have them in a folder in XP Mode. Though I also tried them when they were in a folder on the host machine.
A CD-DVD issue sounds reasonable. Though it's not an old drive, this laptop and the drive were bought together from Dell about 11-12 months ago. It's a Precision M3800. The drive is a DW514 (DVD Recorder).
I'll let you know after I try mapping an .iso
I was checking the dates of some of the maps from the updates. So your checking those files confirmed what was installed and that Update 3 isn't cumulative. On the ProFantasy FR Atlas page they have a text file that lists all the maps that are in the FR Atlas and Updates 1 & 2, which was helpful.
Also make sure you copy over any patches, etc into the XP mode system as they won't install into XP mode unless you do that.
The Start map of the Atlas changes to the update 2 one I mentioned after the Update 2 patch is installed.
Out of curiosity can you tell me what is the last files, newest, you have with a 1999 date and what is the first one, oldest with a 2001 date. (I'm trying to figure out which files you are missing or need updates of.)
I never had to do an .iso mount of the disk. I'll have to dig my FR Atlas out to get the exact name of the disk, but FR_ATLAS sounds correct. I need to dig my disk out of storage to be sure.
Is your .iso mount in the XP mode? That will make a difference given that XP mode is its' own separate system.
I'm on an old Dell laptop that is about 4-5 years old and it has CD-DVD drive issues with older programs on disks.
Maybe Ralph or someone from ProFantasy support can send you the files in the updates with instructions on how to manually install them. I think the updates just add in stuff to the maps folder but I'm not entirely sure. I do know that some of the files it adds are not just maps.
At least we now know that your FRIA disk is good an not the problem.
The oldest of the map files is "Bawa" 8/17/1999 and the newest is "30005 Aru" 9/12/2001.
Yea, the iso mount is for the XP Mode, their is actually a setting/option on the machine Tools > Settings to mount an iso as the DVD drive.
I've researched .cab files and it sounds like I should be able to extract the files from them, but 7-zip says it can't do them. Any idea if that might be an option?
The only other thing I saw was a Microsoft way to decompress .cab files for Windows.
I do have a Read Me for Update 2 Update1 & 3 never had any Read Me files) so that will help narrow down some of what you need updated or missing. I did a copy and past of the Read Me text latter in this post.
The Updates 1 & 2 files think you need are about 60-70 MB files of maps and other files that go into the maps folder.
Do you have a map titled B1dSWlc with a date of 3-7-2000? If yes then I know what Update 2 files you need. (They are about 51 MB.) (This omitting anything Update 3 put a new version of in since you have any Update 3 newer maps.
The 5450 Yulash (10-6-1999) map I mention ought to be the last new map from Update 1, now I just have to figure out what maps are in Update 1 that you ought to have in the folder, not counting any Updates 2 or 3 replace.
What is the newest file you have with a 1999 date in your maps folder? That will help me figure out what the oldest Update 1 file is.
After that we just need to get Ralph or some one from ProFantasy to send you the files or to say it is ok for me or someone else to send them to you, so you can manually add in the files you need from Update 1 & 2.
The Read Me for update 2 is:
Update 2 - February 2000
New Maps Within This Update
The following maps are additional to those within the Atlas and Update 1:
Top-Level Maps:
30130 Realmspace
Overland Maps:
30015 Bandit Valley
30016 Beachhead
30025 Coral Maze
30036 Firethorn Swamp
30063 Mad Monkey Isle
30072 Mulberry Vale
30074 Oasis of the White Palm
30084 Qui
30112 Tsuta Island
30119 Zarastro's Isle
30174 Opawang's Dead Lands
Akari Island
Amn
Anauroch
Cantrev Aithe
Desert of Al-Alisk
Desert of Desolation
Durpar
Fochu Peninsula
Great Rift
High Dale
High Forest
High Moor
Island of Gardens
Kozakura Section
Kozakura
Lurkwood
Maeshi Province
Michaca
Miyama
Nether Mtns
Neverwinter
Nexal
Pirate Isles
Ra-Khati
Riya's Mountain Map
Sea of Fallen Stars
Sword Mtns
Tethyr
Tuern
Turmish
City/Town/Village Maps:
30002 al-Anwahr
30005 Aru
30011 Balanzia 2310
30012 Balanzia 2607
30014 Bandar al-Sada'at
30048 Hawa
30052 Huzuz
30054 Court of Enlightenment
30055 Kao Te'Lung
30067 Mgaiswalu
30073 Muluk
30078 Panchengjuduohuh
30079 Pasar
30080 Pe Nok
30088 Saihoji
30113 Tu Pe
30116 Wafang Garrison
30122 Skull Island
30123 Lower Skullport
30124 Central Skullport
30125 Upper Trade Lanes
30126 Upper Heart
30137 Plaza of Eternity
30139 Ruins of Moradask
30144 Tamanokuni
30145 Mura
30175 Nakamaru
30180 Nakamaru Entertainment District
Maskyr's Eye
Skullport Overview
Dungeon/Floorplan/Miscellaneous:
30000 Abandoned Bathhouse
30001 Adnan's Tower
30003 Al-Bidir Sallah
30004 Ali's Warehouse
30006 At the Oasis
30007 At the Oasis Bathhouse
30008 At the Oasis Caravanserai
30009 At the Oasis Mosque
30010 Azaltin's Palace
30017 Benju's Donjon
30018 Blue Badger
30019 Boom
30020 Caravanserai
30021 Citadel of Martek
30022 Clerical Tent
30023 Colored Bubble
30024 Compound
30026 Corsair Council Building
30027 Cross-Section of Pyramid
30028 Crypt of Al-Alisk
30029a Crypt of Badr Al-Mosak Lower
30029b Crypt of Badr Al-Mosak Upper
30029c Crypt of Badr Al-Mosak Side View
30030 Citadel of Martek
30031 Black Abyss
30032 Garden of the Cursed
30033 E'do Formal Gardens
30034 Fakhira's Lair
30035 Fire Newt Tunnels
30037 Fochu Crypt
30038 Forbidden City
30039 Mount of Forgiveness
30040 Gantar Kraok's Lair
30041 Gauntlet
30042 Golden Mosque
30044 Gorar's Barber Shop
30045 Guard Tower
30046 Gua-Sar Caves
30047 Halls of Upper Priesthood
30049 The House of Al-Kamari
30050 House of Heavenly Sand
30051 Hu Sen's Cave
30056 Keep of the Lizard King (sketch)
30057 Ko Dun Kin's Townhouse
30058 Kordan's Master Maze
30059a Krak al-Niraan Level 1
30059b Krak al-Niraan Level 2
30059c Krak al-Niraan Level 3
30059d Krak al-Niraan Level 4
30059e Krak al-Niraan Levels 5-7
30060 Large Courtyard House
30061 Library at I'ama
30062 Lihat Observatory
30064 Mahara's Vale
30065 Marble Citadel
30066 Mazdaghani's Room
30068 Mobius Tower
30069 Modest Domed House
30070 Mosque of Kor the Old
30071 Mosque of Najm the Adventurous
30075 Pagoda of Panchengjuduohuh
30076 Palace of the Enlightened Throne
30081 Perpustakaan
30082 Pilgrim's Gate
30083 Plundered Tomb
30085 River Hidden
30086 Ruined Farm at Balanzia
30087 Sacred Well of Istishia
30089 Sakina Falls Complex
30090 Sambuk
30091 Setsu's Minka
30092 Shafazal's Oasis
30094 Shao Mountain Outpost
30095 Shattered Shrine
30096 Sheik's Tent
30097 Small Courtyard House
30098 Snake Caverns
30099 Snake Pit
30100 Suijeng Inn
30101 Sumitra Tower
30102 Sunken City of Pazar
30103 Su-Rai Vault
30104 Tempat Larang
30105 Temple
30106 Temple of Istishia
30107 Temple of Set
30108 Terrapin Isle
30109 Tomb of Amun-re
30110 Tomb of Po Nih
30111 Tower House
30114 Under the Pillar of Martek
30115 Underground Complex
30117 White Agate's Tower
30118 Zakharan Market
30120 Zarastro's Keep
30121 Zaruq
30127 Dungeons of Skullport
30131 Krak al-Shidda
30132 Money-Changer's Tomb
30133 Dungeons of Krak al-Shidda
30134 King Shaddad's Tomb
30135 Jade Palace of the Necromancers
30136 Temple of Ishistu
30138 Catacombs of Moradask
30140 Pyramid of Kagamemni
30141 Tomb of the Crocodile Princess
30142 Bone Pavilion
30146 Monastery-Temple
30147 Shoen Residence
30148 Small Town House
30149 Commoners' House
30150 Commoners' House
30151 Reception Hall Daimyo
30152 Peasant Minka
30153 Town Inn & House
30154 Temple Main Floor
30155 Ito-Jo
30156 Ito Castle Level 1
30157 Ito Castle Level 2
30158 Ito Castle Level 3
30159 Ito Castle Dungeon
30160 Ito Castle Large Tower
30165 Ito Castle Small Tower
30167 Beneath Ito Castle
30168 Doi No Fugu
30169 Ko's Minka
30170 Opawangchicheng
30172 Opawangchicheng Dungeon
30176 Nakamaru Castle
30177 Winter Sect Temple
30178 Wealthy Samurai Compound
30179 Middle-Class Samurai Residence
Baghla
The Prismatic
Corrected/Updated/Modified Maps In This Update
These maps are included in this update because they have either been:
(i) Corrected due to feedback from Atlas users
(ii) Updated to include more detail, or have been necessarily updated
due to the addition of new maps
(iii) Were accidentally omitted from previous Atlas releases/updates
0030 Temple of Selune
0040 Manor of the Sea King
0220 Undead Castle
0230 Yeoman's Loft Bank Interior
0240 Polaris Vault Interior
0300 Ilefarn Area D General Living
0590 Lost Level
0640 Hellgate Keep Surface Features
2140 Hall of the Beast-Tamers
2220 Rainbow Falls Monestary Interiors
2230 Deserted City of Kushk
2710 Shrine of the Heart
2810 Temple of the Wyrm
2820 Hill Lair of Ueurwen and Ralas
3240 Citadel of Black Ash
3700 Aithelar
3770 Arrabar
3850 Beorunna's Well
3920 Caradoon
4010 Delia Enclave
4040 Dragonspear Castle
4060 Dzibil
4470 Memnon
4490 Menzoberranzan
5050 Trenahess
5430 Yeoman's Loft
5760-UMLevel03S
5810 Killing Tree
6590 Thri-Kreen Village Ground Level
6720 Temple in the Sky
6730 The Flaming Tower
10020 Blackfeather Bridge
20006 Fochu
20007 Jasuga
A1
Amarune Island
Anauroch
B1alc
B1aSElc
B1aSWlc
B1clc
B1cNElc
B1cNorth
B1cNWlc
B1dlc
B1dNWlc
B1dSElc
B1dSWlc
B2bNElc
B2bNWlc
B2bSElc
B2bSWlc
B2dNWlc
Battledale
C1clc
C1cNElc
C1cSElc
C1cSWlc
C2aNElc
C2aNWlc
Cormyr
Daggerdale
Deepingdale
Evermeetlc
Featherdale
Grandfather A
Grandfather B
Ilighon
Kings Forest
Lantan
Mazticalc
Mistledale
Moonsea
Moonshaeslc
Myth Drannor Ruins
Nelantherlc
Phlan LAM
Sembia
Spiderhaunt Woods
Tasseldale
Ten Townslc
Toril
Veilstone
Viledel's Isle (renamed)
Zakhara
If it would help, I created a directory listing of all the file in my FR Maps folder. It's just a plain text output of dir (command line: "dir >Contents.txt"), but can easily be put into Excel to have columns etc.
I figured out what files you are missing.
If Ralph or someone from ProFantasy can send them to you or give me or some one permission to send you a zip of them so you can install them manually. You'll have all the new and updated patch maps and files.
This is what you are missing
Update 2
Missing newest and oldest and all files with dates in between.
Zakhara.FCW (2-21-2000) (Newest)
Overland Maps.bkm (2-11-2000) (Oldest)
50 MB (414 Files)
Update 1
5450 Yulas (10-6-1999) (Newest)
3910 Caer Callidyrr (8-23-1999) (oldest)
Note, that 3910 Caer Callidyrr appears to be an updated version from the one you currently have. The One you have has an 8-22-1999 date and 8 other maps show a 1 day difference from the one I have, but you have the A2 8-24-1999 dated map though for some reason.
21.6 MB (32 Files)
Total 71.6 MB (446 Files) needed.
Also some of your files for some reason show a 1 hour latter difference from the ones I have.
for the quick answer.
I've been trying to get an answer from TSR/WotC regarding it for the past few days and looking when I had time to see if they ever made them in another format.
WotC has dropped all support for it and several older computer medium products. I have seen WotC allow files,patches etc. for other computer products to be hosted on other sites and some of those sites also have some of those patch files in other formats to deal with newer Windows issues, that never had an "official" version like that.
If I hear anything regarding the FRIA patch files I'll send LordEntrails a PM.
I really appreciate all the help and effort.
Hi guys,
I realize this is nearly five years old, but was a resolution ever found? I have exactly the same problem. I can install the Atlas and Update 3, but 1 and 2 don't run.
Thanks,
I installed it fine on latest version of Win 10 a couple of weeks ago on my new computer (Program and all patches). The only issue I had was that my streamdeck software somehow prevented setup from continuing, it just hang without opening the GUI. Once I terminated the streamdeck software, the install proceeded just fine.
To check if any software is blocking an installer, you can open up task manager, go to the details tab and see if you find setup.exe there (or whatever the name of the installer). Then you can right click on it in the list and select Analyze Wait chain. If there is anything there at all, that's what blocking it.
Did you find a version of 2 that wasn't bugged? Every copy of the Update 2 I could find was a broken ZIP file, meaning I couldn't even TRY to install it.
Well, yes, I downloaded it from the official Wizards website some 20 years ago, that version have always worked fine. Unfortunately, I don't have the rights to redistribute it, so I can't provide you with my copy.
You should be fine with just Patch 3 though. Patch 3 was designed to completely replace the others. I know some discrepancies have been reported up through the years (of which some of these are noting more than old files left behind that were replaced by others, just not deleted when you install the update), but in general, patch 3 is designed to be the complete package, and can be installed without patch 1 & 2 installed.
Hi all, I recently found my old FRIA cd in a box in the attic, along side a second CD with the downloaded updates.
I had to get a friend to move the contents of the CD to a USB since I have no CD-Rom drive in my laptop.
FRIA installed no issues from USB on my W10 machine, but I am having the same issue as others above trying to get the updates 1 & 2 to install. Keep getting a message to insert the original CD. Even tried copying the install files to C: before running them but no joy.
Has anyone found a way to bypass the need to insert the original CD, or extract the data from the .cab files?
Buy a portable cd/dvd drive? Probably $20-$30 USD.
Easiest is to just install patch 3. Unless I remember incorrectly, Patch 3 doesn't require the CD, and should be the only one you need (see my previous answer above)
