Consistent crash with print wizard
                    I installed a new printer. Everytime now that I try to use the print wizard, the program crashes with the following message. Default printing does not give the results I want.
Problem signature:
Problem Event Name: APPCRASH
Application Name: fcw32.exe
Application Version: 0.0.0.620
Application Timestamp: 560df04d
Fault Module Name: fcw32.exe
Fault Module Version: 0.0.0.620
Fault Module Timestamp: 560df04d
Exception Code: c0000005
Exception Offset: 00028551
OS Version: 6.3.9600.2.0.0.768.101
Locale ID: 1033
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: d1d9
Additional Information 4: d1d94a13d3609d6b740644c12508f581
                            Problem signature:
Locale ID: 1033
If your trying to print to a pdf converting program some have problems with certain computers and with different operating systems so try another PDF creator?
Also, try printing a smaller map too.
1. Blank PDF if sheet effects were on
2. Fine PDF if sheet effects are off, but of course it looks like garbage
3. Program crash when trying to access File->Print (or Print Wizard)
Does anyone know a print to PDF app that's free and works with this?
Thanks
Just using print works okay.
What works best is to save your map as a high res PIN and then print that.
What quality that comes out is so much better than what I see on my screen.
