Dungeon Designer 3 - Wall issue with drawing rooms
Greetings,
I have been following the instruction on how to draw complex rooms on page 203 of the Tome of Ultimate Mapping but after completing the instructions I end up with this result;
http://i.imgur.com/0f4tZKT.png
When I delete the room and start anew the result is the same (even after several tries). All seems to go well until I change the properties of the copy of the room to turn it into walls (step 23 of page 205). I have attached the map and you can see a similar looking room next to the flawed one which I have managed to draw without issue using the same instructions. Node editing yielded zilch result, so what goes wrong here?
