Bevel generates artefacts
Hi,
I have a problem with the bevel-effect, when turned on for Scrublands_VH.PNG-fill, it generates strange artefacts on my areas.
Any idea what this is?
The areas are created by using the poly tools.
It only happens on some zoomlevels and on export it depends on the number of pixels. Looks like some kind of interference-pattern.
I also have this problem when using 2 sheets of this fill on top of each others.
Any idea how to prevent this?
The best solution is to change the color slightly on one of the layers if possible to avoid this effect, possibly by changing the entity or by adding a differently-colored entity below the problem one.
I'm not sure how solve the problem, if the "holy" area is a transparent one. Any suggestions?
