TF Pro 2.3 - ice world creation?
                    Hi.
I've been gone a while, and inbetween times, switched to Linux, having finally had enough of Windows unreliability; so, I'm stuck with xx2 versions for the moment; which brings me to Fractal Terrains Pro 2.3, which works very nicely under WINE in Linux, by the way
The problem: I'm trying to create an ice world via stats from Traveller (Classic Traveller, not Mega Traveller, etc) and the Heaven & Earth system generation package. The problem is that try as I might, I cannot get a world that looks like a hunk of ice, or even covered in snow when using FT 2.3. I'm sure it's a User Error problem, so can anyone give me pointers in generating a planet-sized hunk of very cold rock, please?
The world sheet stats from H&E is here: http://www.coldwarprovost.org.uk/tlg/rampart/H-and-E-sourcefiles/Orbit 2 (5) - Rampart I Gamma See.HTM
The very basic world map generated by H&E is here: http://www.coldwarprovost.org.uk/tlg/rampart/H-and-E-sourcefiles/Orbit 2 (5) - Rampart I Gamma See.GIF
As you can see, the map generated by H&E appears to diverge from the stats (stats = 6-% water, map shows all water/ice?!) so, with all the above in mind, can anyone tell me what am I missing in order to create an FT world that's a rather big solid snowball in space?
Ta muchly,
Roger
Ta muchly,
Roger
Looking at the altitude view will show no change (unsurprising). Rainfall will be pretty much 0 (again unsurprising). Temperature varies from around -100F to -20F. Climate view shows all white with just a little bit of shading on mountain edges.
One way to get a world that would look like an iceball is to use the Image climate shader and a picture of an iceball with standard temperature parameters (I don't recall if FT2.3 supports this shader). Starting with a picture of Enceladus cropped to get the light to dark things, the image climate shader will give a picture like that shown in the attachment. I did set the sea percentage very low. This shader trick won't work with a truly icy world due to the way that it converts temperature and rainfall to colors.
VERY good points, and thanks - I'll report back after work with some results
Cheers,
Roger
Tried again last night to get an iceworld based on the suggested settings above, but no joy, guess I'm still doing something wrong
Cheers,
Roger
The climate images weren't doing the trick, so I tried a plain white climate image, and presto, progress. However, the gaia map is still plastered with a lot of the rainbow, and for that, I'm having to go in and manually change things. I'm well knackered now (difficult shift), so I'll do some more on this tomorrow.
Cheers for the suggestions above, they've been very helpful
Cheers,
Roger
Sometimes, it's the easy dodges that are most productive in an RPG
The first two images used the image climate of a blank white image, coupled with the pre-loaded ice-002 colour scheme. The first is the flat 'Sphere Map' projection, the second the more familiar Icosahedral Traveller-like projection.
The last two images used the same settings as mentioned above, but I went into 'Map' -> 'Lighting and Colour' -> 'Altitude', and changing the oceanic colours to one value.
I haven't used Terraformer to add clouds yet, that'll be for the finished imagery, and that'll happen over my weekend (Sun-Mon)
Enjoy
I wasn't happy with the blue, they looked too much like liquid ocean, not frozen wastes, so went with a similar look to the first attempt, with the following World Settings:
Highest Peak: 6000 feet
Lowest Depth: -2000 feet
Circumference: 5000 miles
World Seed: 1815725495
Roughness: .93
Percent sea: 63
Land Size: 1.04
Continental Shelf: -100 feet
Fractal Function: fBm
Axial Tilt: 24.9998674749432
Albedo: 0.4
Light: 1
Greenhouse: 1
Rainfall base value 900 in/yr
Random amount 35
This, combined with the white Image Climate, and alterations to the altitude colour settings mentioned above, resulted in the following...
Comments / Opinions / Critiques, please?
Cheers,
Roger
Comments, suggestions, critique, please?
Cheers,
Roger
Thanks
I've got a shedload more worlds to work on for the system I'm mapping, see this link, which will update as I meander - I mean progress - down the path
How are the hopes for a native Linux version of the packages coming along?
Cheers,
Roger
