I have downloaded the fireplace file, but I cannot get it loaded into CC3 for the life of me, everything that came with it is PDF format and the cc3 is reading FSC, any ideas?
You're talking about the "Shessar's Fireplaces" download from your registration page? If so, are you sure you downloaded the correct file? I just grabbed it to test, and that file is an .exe that when run will install into your CC3 directory automatically (you may need to right click on it and run as admin), there are no pdf files included in that installer at all.
The fireplaces should be in #Symbols\Dungeons\Shessar\Fireplaces after running the installer. There should be a symbol catalog file in that location you can open.
no, its not like that, its like this: CC3/symbols/dungeons/filled then there are the files but there are in PDF format, and I did run them through admin, still not working
Also, if you are seeing the PNG files as PDF's then perhaps your system has a problem with it's file type associations?
