How to export high res
Hi,
I'm experimenting with google maps and cc3 and it works nice so far. My biggest problem is the limitation of the CC3-export to about 9.500x9.500 pixles.
I would like to export at about 50.000x 50.000 and the only way to do this seem to split the export and then stitch eversthing back together.
Has anyone an idea how to do this?
If I'm using the rectangular export, the scaling isn't right, because I cannot make certain to export exactly the same areasizes.
The best would be a macro, but the only thing I can find is [i]SAVEASM[/i] and this saves the whole file as FCW.
Thanks for your ideas.
Torsten
Torsten
For use in a macro, use WBSM. This is the macro version of the rectangular export command. The file type is determined by the extension you give the file name. It will use the current export settings.
WBSM allows me to generate a macro containing the needed commands including the coordinates what to export.
But, I am not sure because I am new to CC3+.
I am told that my 10,000 x 12,000 map is too detailed and that the computer will eventually stop on me.
What I am thinking about is doing a portion of the map and transferring it has High Res image (PNG) into a template FCW.
In affect - stitching the images together to create a single highly detailed map.
I think that you are doing something different but similar, but I may be able to use it for my own purposes.
