NEW DRAWING WIZARD ISSUE: CC3+ w/ DD3
                    When creating a new file from the New Drawing Wizard templates, I have available to me a map style called "CC3 dungeon".   When I select this template and start to work with it, I get the following error when I click on Default Wall Icon from the tool menu:
No matching draw tool
There is no draw tool matching your selection in the current draw tool style.
Any ideas why this is happening? Am I not suppose to use this style in DD3? Rather new to this mapping software, so please bear with me; but it would seem to me that if this template is available it should allow me to use some of the base tool features..yes? When I select a different template like DD3 dungeon, I do not get this error. Are there cases when you select a tool that there might not be available a matching draw tool?
@anyonenotRalf:
The drawing tool buttons looks for certain tool names, like the wall button looks for Wall, Default when you click it, but this sample subset doesn't have any tools named Default. You can still right-click the buttons to get up a list of appropriate tools.
Just the same, please let me know what you find out @Ralph.
But taking it a bit further, there are styles out there that do not have a certain kind of drawing tool (Often because that particular type of tool is not needed for that style of map), so you may encounter this from time to time. But for his particular style, as long as you own DD3, you should really never use the CC3 dungeon style, but stick to the DD3 dungeon one.
