Adding another floor?
Using CC3, I started a new drawing with three floors. Now that I'm into it, I've decided I'd like a dungeon level as well. I can't figure out how to add another floor to this drawing. Can anyone help?
    Adding another level after the fact is tricky. I would do a new set of maps at the same size, just with the added floor, and then use Clipboard Copy to copy my old floors into the new drawings.
  • OK. Ya gotta do what ya gotta do, I supposed. Thanks.
    edited October 2015
    I do it this way.
    Draw up the first floor with major areas like the doors and stairs.
    Save as to filename 'second_floor'.
    Save as to filename 'third_floor'.
    That way stairs line up.
    Delete exit doors from the floors above ground/first, unless you are adding outdoor stairs.
    Edit each floor's map separately.
    Export pngs from each map. Now you have a 3 level Inn or other building.
    I used to have examples of this, but I haven't updated them onto my new site yet.
