No effects in CC3+
                    I'm having an issue with CC3+ and I'm hoping there is something easy I am just missing.  I created a map with the effects off (old habit from CC3) and once it was mostly finished I turned on the effects to check out a couple spots to see if I needed to clean them up.  However the effects didn't show up.  I tried the DD3 default settings for effects, then I tried a custom set-up I had used in CC3, all to no avail.  The map is pretty, but without effects it lacks, well, effectiveness.  Am I missing something obvious or am I doing something dumb that should be obvious but I am just missing.
Thanks
                            Thanks
Spot on as always. I had clicked the "hide all" button somewhere along the way and hadn't unhidden the merge sheet. Thanks for the help.
Tim
