Right Click Error on Change Properties?
 ArgoForg
                Newcomer
ArgoForg
                Newcomer
                    Good morning, all.
Had an issue with CC3+ but I am unsure if this is a problem that has occurred within CC3+ or if this is something that has happened since adding the Vintyri symbols for CC3+ (I do not know if it tweaks the menus), so I thought I would ask openly and see if anyone else is experiencing this error. I apologize in advance that I have no screenshots, as my home computer is currently lacking internet, so I'm having to send through my phone.
Tonight while creating a city map with CD3 (CC3+ version), I decided to create a terrain feature. The original map was started from the CD3 templates (village, I believe). At any rate, I pulled down the drawtools dialogue (and opened the advanced options) to select the Schley Overland style to create a farmland area. The area was not going to fill correctly (since it wasn't created using the Schley overland style), but that was no biggie. I created a filled rounded poly.
At that point I right-clicked the Change Properties button to select Change Fill Style, but I got an error dialogue box with the message-- paraphrasing here, "Error: Cannot Open change.mnc". I got the same thing when I attempted this after starting a new map, and using the buttons to cycle from CD3 to the tools for DD3 and CC3. I can still access the fill style dialogues through the CHANGEFS command in the command line, but right-clicking gets me nothing.
I have gone ahead and uninstalled and reinstalled, and although at the outset the right-click for properties worked in CC3+, the same error popped up again after I'd opened the drawtools and tried to change fill styles.
Anyone else seen this error and know how to fix it?
Here's the link to the restore zip:
http://www.vintyri.org/downloads/vss2_cc3plus_restore.zip
