Overland map Request Island radiance
                    I'm looking for and overland map for the start of my D&D 5e campaign. That i can print and alow the players to use. The island is split in two visible areas for the players. They start off being sucked through a maelstrom at sea, and land somewhere on the edge of the plane of water and earth. The area is defined by islands spaced so far apart that ancient magical teleportation  gates are the only way to reliable traverse the great expanse between islands.
The region they start off in needs these visible features the players can see.
Coastal desert surrounded by ocean and sheer cliffs. with a canyon between the cliffs(mountains) that has a walled fort to the other side of the island not visible to the players yet. Island Has two sides
Points of interest that they can see on the map should be a Lone mountain full of mines
Oasis with a few palm trees
Ramshackle home base made from survivors of the maelstrom.
Ancient pyramid temple centered in a ancient forget city set into set far away from base camp.(maybe have it in a recessed portion of the surrounding cliffs.
ancient half buried roads leading from he temple to various locations of the region)
Cave entrance set into the cliff behind the temple.
huge stone Obelisk
ancient huge shipwreck somewhere along the coast.
bandit camp(ramshackle) other survivors from wreck that are a separate faction.
Ancient half buried city other than the one with the temple.
Kobold city/fort with a mine set behind it.
I would like the players to explore this large lone Mountain with mines and the oasis pretty much right from the get go. The mountain is how they get a good look of their surroundings and when i hand out the regional overland map. the island is a two parter, this is just one half of the island the other is through the canyon with the walled for in it to the other side. also a few other eye catching features that might entice the players to explore the land are welcome but the land should seem mostly desolate. I can share some lore and backstory too about the island if that helps int he creation juices.
huge stone Obelisk
The menus at the top of my site: Nothern Hemisphere has several island maps and Generic has some atolls.
OH i forgot to mention scale. Area should be around 100 mile region or so. Something i could print out and put the the table. tables about 4 by 3 feet but it doesn't have to be that large something around 24inches would be better.
