What did I do wrong to cause the extra wall at top of the map
Hi All,
Still in infant stages of learning CC3 et al, and here is a quick 5 min map that I drew that includes an extra wall for no reason. I drew the rooms top left then bottom right, the used the corridor tool to make the convoluted route between the two, but from no where a new wall appeared
Any idea's what I did wrong?
TIA
Adrian
    I'm not exactly sure how it happened, but you had an extra node at the end of that hallway (where it connects to the room). With wide paths (what the walls enitites are), if two nodes are closer together than the width of the line, it can cause artifacts like this in the display. Just move or delete one of the nodes to get rid of it. I've attached the fixed version.
  • Thanks Ralf, I obviously did something stupid - I just could not see it or delete,thinking I should re-read the object selection section of the pdf - have to say Corel has a better object manager
