red crosses instead of pics...?
Hello,
some time ago I've created a map using some of the pictures from CSUAC collection. It was before the collection was converted to CC3 symbol catalogs so I used ordinary pictures then.
Now, that the CSUAC coll. is presented in the form of CC3 sym.cats I'm using these. Unfortunately the symbols in the map turned into the "wel known" red crosses. I suppose it's because the former locations of separate pictures are gone.
Nevermind - I would like change them for symbols from the CSUAC sym.cat. Unfortunately - even if I load the correct sym. cat. and select the right symbol it immediatelly changes to "red cross" :( (see the attached picture).
Please, does anyone know how to get back / change the "red crosses" to "legal" symbols / pictures?
Thanks in advance
Pavel Svika alias Dron
PS: hopefully I'll attach the pic in next topic.
Thanks in advance
Best way to test if this is indeed the issue is to start a new map, and try placing the symbols there. If that works, you know the above is the problem.
So the problem is with cached symbols.
Nonetheless - after erasing the "old versions" from the map the behaviour did not change until I purged the symbols using Symbols -> Purg Symbols. Since that I can use the symbols from new sym.cats. for drawing again.
The only problem I had was to search for all the problematic symbols since my map is BIG and some symbols were small. Is there any convenient way to search for / zoom to some symbol...?
Thanks for swift help
You can get rid of all the symbols of a particular type by just using "Delete" from inside the symbol manager, but of course, that only help if you don't need to know where the symbols were on the map before deleting. Of course, you can also use "Replace" in the symbol manager to replace a bad symbol with another symbol (Perhaps something that stands out well on your map so it is easy to hunt down)
-Open the Symbol Manager and rename all of the symbols that show as red x's by putting another character at the end of the name. So if the name is "WebWall kpl-b" you might rename it to "WebWall kpl-bB".
-Open the new symbol catalogs and click on each symbol that you want to fix. Don't place it, just click on it to add it to the Symbol Manager.
-Use the Replace function in the symbol manager to replace each red x with the correct symbol.Then delete the red x version.
The only problem I've run across in this is that sometimes the symbol orientation is different so will be placed in a slightly different location and will have to be dragged back to where you want it.
Like I said, this takes time, especially hunting down the new location of the symbols within the catalogs. If someone has found a faster way, I'd love to hear it.
(Just a note, the CSUAC was reorganized for the sake of future updates. So while it is a pain to fix everything in your maps now, future additions to the catalogs will not cause the same issues and as the amount of art grows it will be easier to locate the symbols within the new file structure.)
Am I right that CC3 decide to replace pngs every time if the path to the png is not anymore ok?
Does this mean: Every time if i decide to change the path structure of my hard drive a bit I heave to fear to damage all my maps I did in the last years?
With best regards
Robak
As an alternative, you can store the symbols in a subdirectory relative to where you store your maps. The downside here is that all maps that use the same symbols must then be stored in the same directory (no subdirectories).
None of this helps however if you completely reorganize your collection. The internal directory structure of your collection needs to stay the same.
CC3 doesn't 'replace' png's. The png files are not stored inside the map itself, so CC3 must have access to the original symbol to be able to show it. If the path is invalid, CC3 doesn't know how the symbol looks, so it cannot do anything but displaying the red X.
Best regards
Robak
