(CD3) Drawing bends (modern roads)
Greetings dear people!
I have CC3+ v3.67 installed with DD3 and CD3 with Symbol Set 3 (modern). When I attempt to add a bend (I can't see the full name of the image) I first get this;
http://i.imgur.com/rWxs7KM.jpg
Seems normal. When confirming with a left mouse click the program shows me this;
http://i.imgur.com/APYvFHn.jpg
This seems strange. Left clicking only places the straight line and not the bend. I can place cross roads and the like without issue but the two bends I can not. What am I doing wrong?
Edit;
Found it, right click and checking off "Disable smart symbol" did the trick.
    Note that this behavior happens because the symbols you are placing are connecting symbols. They are designed to let you simply draw the entire path, and CC3+ will pick the correct piece to fill in (straight or bend) to fill the entire path. This is much faster and easier when compared to placing them down individually. But if you do wish to place them one by one, turning off smart symbols is indeed the correct option.
