64-bit Windows? Running out of memory when saving a map? Enabled LAA...
                    TL;DR - use a small, free app to give you more memory access for CC3/CC3+ on 64-bit Windows.
Details:
While having a discussion on another forum (the Fantasy Grounds VTT forum), I did some investigation and discovered that both the base CC3 and CC3+ application executables haven't been compiled with the Large Address Aware (LAA) flag set. Whereas the CC3/CC3+ executable (fcw32.exe) is a 32-bit application and limited to using 2GB of memory on a 33-bit operating system, if the LAA flag is set on a 32-bit executable, and the application is running in 64-bit Windows, the application can use 4GB of memory. See the "Virtual address space per 32-bit process" entry in the "General Memory Limits" here: https://support.microsoft.com/en-us/kb/889654 This /LARGEADDRESSAWARE flag doesn't have any impact when running the same executable on a 32-bit system, where the memory use would be limited to 2GB.
Now, there may be a technical reason why the ProFantasy devs haven't used this compile option when making the fcw32.exe file. Hopefully they might see this and comment...
The good news is, that with a simple application (there are a number available on the 'net) you can set this flag on your CC3/CC3+ application and immediately have access to more memory.
Steps:
1) Locate your fcw32.exe application file in your CC3/CC3plus directory and make a backup copy of it.
2) Download the LAA ZIp file from here: http://www.techpowerup.com/forums/threads/large-address-aware.112556/
3) Run "Large Address Aware" application from within the ZIP file.
4) Click the "..." button in the app and select the fcw32.exe application located in step 1.
5) Check the "Check this box to enable the application..."
6) Click the "Save" button.
7) Run CC3/CC3+ as usual.
You'll find that when you're exporting (save as) your maps to PNG, JPEG, etc. that you'll experience the "You don't have enough memory to export at this resolution" much, much less (and only for very large maps) and also CC3 should crash much less when exporting large files.
I've done a number of tests, exporting large maps with a lot of effects enabled, and this has allowed me to reliably export large maps that I couldn't previously do.
You can always roll-back to your backup of fcw32.exe (assuming you made a backup copy in step 1 above) if this doesn't work for you.
                            Details:
Steps:
I can confirm that this worked for me... well that it is rendering, at least. Looks like it will take a while! 12 of 44 passes! I doubt I'll ever print this one, but it's nice to have the option now.
Of course, said render took about an hour and a half to finish. XD So I won't ALWAYS export in that size - if I just made a small update to a map and want to render an image to show someone, I'll still go with lower res to speed up the rendering. But it's nice to have the option now of putting out a much higher res image every now and then.
