Resolution Help
Hello, I'm new to the ProFantasy products and not very technical. I've created my first map and when I open the image it looks great, but when I try to zoom in, or print it's becomes blurry. Can someone help me with what I need to do to print my map 8x8 with better resolution so it won't be blurry. I appreciate any help.
  • What type of file did you save it as?
    What resolution?
    Make sure that when you save your map as an image you hit the option button in the 'save as' dialog (After selecting the appropriate file type, but before hitting save), then set an acceptable resolution. The more you want to be able to zoom into the exported image, the higher this resolution will need to be.
    Note that as for printing, you should usually print from within CC3 itself, and not from an exported image, because the CC3 file is generally always more detailed than it is possible to export to an image.
