CC3 Viewer
Just a couple of questions about CC3 Viewer:
#1 Does Viewer allow users to click hyperlinks in the map?
#2 Does the Viewer have less system requirements than the CC3 program?
#3 Similar to #2, can maps be used (scroll around, click links) more quickly than CC3?
Thanks!
    edited October 2008
    1: Yes. As long as said hyperlinks uses commands the viewer support. It doesn't support drawing commands for example, so you can't have a hyperlink that draws a circle around something. More basic hyperlinks like loading another map works perfectly.
    2: It requires less disk space, but otherwise it is basically the same.
    3: Not really. Perhaps slightly, but drawing things on the screen is the most resource-intensive task in CC3, and the viewer needs to do almost exactly the same as CC3 in that regard. (If you don't have a very fast computer, you'll not want to have effects turned on when you scroll/zoom around in the map, neither in the viewer, nor in CC3)
