I've always used the Arc tool to create curved corridors. Using a smooth Poly works too. Use the Offset Copy command to build the corridor & walls and use a multipoly to do the fills
The corridor was put together in probably less than a minute to demonstrate how to use the offset copy command to build a curved corridor. I took absolutely no time to make sure that the objects were all in appropriate sheets and layers and that lighting effects were working properly.
