Installed CC3+, DD3+ = no DD3+ Dungeon Menu icon!
                    I'm having trouble getting my DD3+ "Dungeon Menu" icon to show up at the top of CC3+ (I do have default "Map Menu").  I've installed, uninstalled, reinstalled and no luck on my desktop (Win 7 Pro).... I get the icons on my laptop installation of CC3+ / DD3+ (Win 8.1) - so I know its supposed to be there.
Do I have to install Update 1 before Update 2, and do I now have to uninstall CC3+ before I can do that?
Can you try running CC3MenuConfig.exe (Found in the CC3+ data directory, which is c:\ProgramData\ProFantasy\CC3Plus by default) and see if that fixes the issue. If it doesn't, do you have a dungeon.mnu menu file in that directory?
(Note that CC3MenuConfig executes and complete silently unless there is an error)
If you have a working install on another computer, you should be able to just copy the missing files over, then rerun CC3MenuConfig.exe, and it should fix the menus, provided all the menu files are actually present. The problematic/missing files here seems to be CC3MenuConfig.exe itself and/or dungon.mnu, which is the menu file for DD3. Both these files should live in the CC3+ data directory, which is c:\ProgramData\ProFantasy\CC3Plus by default.
If you haven't done so, give it another try.
R A Jacobs
I'm having the same problem in that CC3MenuConfig.exe does not exist in the data folder (C:\Program Files (x86)\ProFantasy\CC3Plus) and doing Repairs etc doesn't accomplish anything.
But I did find that CC3MenuConfig.exe does exist in my CC3 folder which is actually C:\CC3 - when I installed CC3 it was accepted wisdom to install it into C:\CC3 folder rather than in the normal C:\Program Files (x86)\ProFantasy\CC3Plus or C:\Program Files\ProFantasy\CC3Plus folder.
Wonder if this is where the problem originates? Also if it being in \Progam Files (x86) rather than \Program Files?
I know ProFantasy is busy trying to figure out this oddity with the missing file, hopefully a solution will be available very soon.
