How to fill with land
I have an old map I drew by hand years ago that I want to digitize. This map is the reason I purchased CC3.
Because the map is already drawn I want the coastline to match as close as I can. I am able to draw a shape but I can't figure out how to fill it with the standard land graphic I've chosen. I was hoping to find something like a fill tool where I just hit the paint bucket and what's inside the lines is filled. But I can't seem to get there.
I am able to use the land mass tool, but it shapes the coastline automatically and I don't want to edit 10,000 nodes to get just the right shape for each tiny section of coastline. I need to do this by eye and hand.
I am new to the program (obviously) so I'm not even yet familiar with all the terms for each tool so I hope I have been able to articulate what I'm trying to accomplish well enough to get an answer.
Thanks for the help,
Chad
    The land mass tool uses fractal lines.
    Here is how I do it.
    Import a png or bmp of the scanned picture/map, etc. I typically place it on Sheet: Screen and Layer: Screen. Or Sheet Screen and Layer bmp. You have to add layer bmp.
    Select a bitmap fill I want to use for the land.
    Select multipoly, right side of CC3, and draw a land mass over the scanned file.
    Then draw any mountain rainges, rivers, etc.
    Hide all but the Screen/bmp layer, delete the picture you scanned and imported.
    Show all to see the results.
    Make adjustments of rivers, etc. if you want to.
  • Thanks. I'm still a little clunky at it but that helped. I got it to do what I wanted.
    I'm not sure what use the freehand tool is. What sort of thing do you use that for?
    I don't. I'm not great at maps, Shessar and Joachim are. I turn out lots of maps that are good for gaming. Some of mine are good and some are awful. I'm working on improving my maps.
  • Well, great or not, you were good enough to help me! Thanks for that. The map I have is 36"x36" so it's going to be a big one on the computer, not something I can scan in to trace. I will have to do it freehand.
    You could scan it in parts, and assemble it in Irfaview, which is free.
    I haven't tried it, but it should be doable.
    And thanks.
  • True, or, I was thinking, I could take a photo of it and trace that. I'll play around with it and see.
