Texturize Sheet Effect
Hello,
I'm attempting to apply the texturize sheet effect. When I am in the texturize dialog and I apply the texture or press OK the texture appears and looks great, but as soon as I press OK or Apply on the sheet effects dialog the texture disappears.
Any help is appreciated.
Thanks,
Terry
Thanks,
Terry
Cheers
Mappy.
I've got the same dead end with texturize on CC3+. Any ideas? Am I doing something wrong?
What texture map are you using for your operations? The intensity range in the texture map can affect the results (if the texture map is mostly mid-to-light grays, then a brightness much above 50% will wash it away almost completely).
