FT3 exported map crashes CC3 when changing fill-style
Hi!
I just started using FT3 today and I exported a map into CC3. Then I imported a map with a style from an annual and did an undo right after (I read that somewhere on the forum) to get the style into my new map.
Then I hide everything except the countours sea sheet and try to edit the fill style of the different sea levels (i.e. use "water darkest Bitmap"). On some parts it works but most of the time CC3 crashes right after closing the edit property dialog.
Any idea?
cheers,
rattokan
  • 7 days later
    How is the detail levels on the coastline on the exported map? Sometimes, the maps exported from FT can be a bit to detailed, potentially causing problems. You may also wish to try to export it without multipolying the contour levels (You can change this by editing the export setting). Note that multipolying is required to be able to make holes in polygons, so this will have an effect on certain elements like lakes.
