DD3 update not working with CC3+
Hi
I downloaded and installed the latest version of CC3+ 3.66 and then installed the DD3 update for CC3+. When I load CC3+ none of the DD3 templates and icons etc are present in CC3+. It is almost like CC3+ does not see the DD3 addon. Has anyone else run into this issue? I'm not even sure where to start troubleshooting the matter. Any suggestions?
Thanks
Eddy
Thanks
Eddy
I have no issues with the DD3 install for CC3+. It appears to be working fine for me.
Okay I did as you suggested. I reran the CC3 Update 1 patch as admin.
The menu button for DD3 now appears as shown in the clip below (main window1.png)
When I click on the DD3 button nothing seems to change in the program, meaning I don't see anything specific for DD3 (map tools etc.)
When I go and create a new map -- Dungeon --- only the CC3 styles appear in the dialogue box.
Seems like the DD3 files are not fully recognized by CC3+ yet.
Any suggestions?
You can always check in the folder C:\ProgramData\Profantasy\CC3Plus\Templates\Dungeons\Wizard to see if the templates are there. If their not I guess DD3 didn't install properly.
Try re-installing it, but deactivate any anti-virus software you may have. If re-installing DD3 doesn't work, try an uninstalling/install of CC3+ and DD3 for CC3+
I noticed that it doesn't work if you try it on the cc3+ welcome screen is what is open.
The instal of DD3 for CC3+ may have had a problem I'm suspecting.
Try doing a clean instal of CC3+ and DD3+. Make sure you run as an Admin and to run Update 1 after you install CC3+
I did a fresh reinstall of CC3+ and DD3+. and ran the Update 1.
All appears in working order now. But I had to run the DD3+ add on patch again after I ran the Update 1. If I just run the Update 1 patch it wipes out the DD3 icons, so I just tried rerunning the DD3+ patch and the DD3 icons and styles came back. Weird.
The kicker is I have to run CC3+ under Admin to get it to work properly. I'm not sure if this is what you mean by "run as Admin" in your above statement. If so, then that is what I am doing now, running the program in Admin mode. Seems to be working now as far as I can tell. Thanks for your help.
