Campaign Mapper Help Needed
I managed to recently get a copy of the Core Rules 2.0 & the Expansion for it & I'm having a problem with the Campaign Mapper.
When I click the "Link With Encounter Button" I get a box op up that says" Core Rules II Busy-Did Not..." or "Core Rules II Not Connected-Did Not..." at the top of it.
The same things happen when I click on an Encounter that is on the NYR.FCW sample map.
I can link an Encounter with the Map Maker program, just not with the Campaign Mapper one for some reason.
Anyway to fix this?
Install wise I did this when I installed it.
Uninstalled my FR Atlas & all patches for it.
Installed Core Rules 2.0.
Ran the CM 6036 patch.
Ran the Core rules Update 3 patch.
Installed the Core Rules 2.0 Expansion.
Ran the Saving Throw patch.
Ran the CR Expansion patch 5
Installed complete book of Necromancers.
Installed FR Atlas and all patches.
The installation for the Core Rules & Expansion are both Custom with everything selected.
Also, can you set up a link with a Core Rules 2.0 Encounter using Link With File in CC3? If yes, please explain how.
One other question the CM is supposed to install the 3 symbol catalogs it has into CC2Pro. I had CC2Pro already installed and would like to know into what folder they are installed in. The CM installer didn't install them into CM. SO I'm going to have to copy them from the CM program into the approriate location in CC2Pro.
Anyway to fix this?
