error installing dioramas set.
i keep trying to install the cc2 dioramas set into cc3 using the compatibility version. and keep getting the following errors (see attached picture). Also, The program wants me to verify the license EVERYTIME I try to install it. None of the other programs are giving me any issues (CD3, DD3, COS3)
Any advice and/or assistance would be greatly appreciated.
Thanks,
MrGrimm (A.K.A. Chris)
Thanks,
The suggestion from Ralf was: 'Please run the file "CC3MenuConfig.exe" from your CC3 program directory by right-clicking it and choosing "Run as administrator". It should execute silently and fix the menu icons for DD3 and CD3, completing their install.
Try giving that a try...
R A Jacobs
Learning CC3+ @ Funny-Shaped Dice
If it still doesn't work though, I would recommend you contact ProFantasy tech support. I know Ralf is trying to find a solution to this problem, and maybe he has a workaround for you.
