Vertical Banding in FT3
My new laptop has a 4K display (well 3840 x 2160) and when I open a FT3 map, there are ugly vertical bands showing through the map unless I reduce the window size to make the map smaller than the "Maximum Horizontal Resolution" of 2048 pixels. Unfortunately the application does not allow the user to increase the maximum (horizontal or vertical) resolution above 2048.
Does anyone know any solution to this, other than to just ensure that my window size is small enough that the map doesn't go beyond 2048 pixels?
-- Pete.
    I don't recall the exact version where the 2048 limit was in place. Please make sure that you have the most recent FT version from your ProFantasy registration page. If it has that limit, there is no solution other than to keep the resolution under 2048.
  • Thanks, I did a fresh download yesterday, so it's certainly the latest public copy.
    I guess that's the limitation for now.
    -- Pete.
