[WIP] SOBRE COELHOS E RAPOSAS: Main Area Map
Hello folks,
I am wrking in more than one map in the moment to try to put my mapping up to date. This one is for my furries setting "Sobre Coelhos E Raposas". My first doubt here is the mountains scale. I am using the Alyssa Faden style in a 3000 x 2400 template, so I am adjusting effects and symbols scale acording. But the mountains do not look right in my opinion. Can you guys give suggestions? The ones in the map below are in a 0.35 scale.
I had the same problem with some of my new maps, one of which is over 5000 miles wide.
The other solution I came up with was using Alyssa Faden mountain bitmap fill and unchecking the scale square.
Example below.
My apologies, I posted Alyssa Faden above. I hadn't checked the fill style with the list command.
Instead of mountain symbols, use a mountain bit map fill.
I experimented with something similar here (http://forum.profantasy.com/comments.php?DiscussionID=3523&page=1#Item_21) with OK results. In this map, I think I had like 2 or 3 sheets for the mountain chain.
Hope that helps some
