Cant choose a grid on new map
                    Hi guys ,
I have a problem with CC3 since 2 days.
I tryed to create a new map then choose a grid (200' x 160' DD3) and i cant click on it.
The only think i can do is to go on choose path then click on it , and nothing happen.
My screen stay at grid selection.
I also cant use "erase".
Any idea plz ?
Thx.
Any idea plz ?
Thx.
- Click the Layer Indicator on the Status Bar.
- Click the box with the F in it.
- Click OK to close the dialog box.
You should now be able to select and modify the grid.The Select Layer dialog box displays. The last box of the HEX/SQUARE GRID layer has an F in it. This indicates the layer is "frozen."
The checkbox clears (the F disappears).
I hope that helps.
Cheers,
I still have the same problem , i show you on SS once i try to select a map 260' it dont work :
http://www.hostingpics.net/viewer.php?id=712649CC31.jpg
I'm here i cant Click on this DD 3 grid 260'. So i click on Select path (it's only thing i can do actually).
http://www.hostingpics.net/viewer.php?id=980813CC32.jpg
Once i choose it i go back on selection screen and no map appeared after that !!! it stay on the default one .
Result >>> http://www.hostingpics.net/viewer.php?id=959009CC33.jpg
PLZ HELP ; ;
fct are templates, fcw are maps.
I'll try to check on forum if there is an old post about it.
thx
I was able to load DD battle maps by double clicking on them in the template selection window.
