Fractal Terrains 3 Sheet setup not working
I'm fairly new to using CC3 and Fractal Terrains, so maybe I'm doing something wrong here. But from what I can tell, I should be able to tell FT3 to send features to different sheets when exporting to CC3. I created a new export settings file (based on the original full export) which sent all 4 contour bars into the same sheet (INFO). I didn't like that, since they overlap unless I use the layer switch buttons; so I went to the sheet setup button, and added 4 sheets. I couldn't immediately tell the relevant map features to select those sheets, but once I left the page and went back into it I could then tell each contour bar to use the new sheet. However, once I export to that they still all go to the Info sheet.
I would appreciate anyone telling me what I did wrong there, or another way to force the contour bars onto a different sheet.
