Grid line thickness
Can anyone please tell me how to change the thickness of grid lines? I can't seem to find it anywhere.
Cheers
  • RelytRelyt Betatester Traveler
    I don't think there is a way to change the thickness of the grid lines. I may be wrong as I am quite new.
    But a way to work around this is with sheet effects.
    On the grid sheet apply a glow effect.
    Match the color to the grid and make sure it's outer.
    Make the strength 8.
    Start really small with the blur radius, like 0.25.
    Then you can play with lower strengths and transparencies to get the look you want.
    edited November 2014
    You can't set the grid line witdth when creating the grid, but you CAN change it afterwards.
    - Simply do "Change Properties", select the grid, right-click to Do It.
    - Then change the line width in the dialog what you want it to be.
    - You should also change the fill style to "Solid", as otherwise you'll have hollow lines.
    - Then click OK and you grid will be changed accordingly.
