Sketch options in drawing-tools
Hello,
is there a more detailed description of the sketch options available?
The only one I can find in the Help-file is:
Sketch - move the mouse, leaving a trail: press CTRL to lift the pen.
The Draw Method Options - Sketch dialogbox gives me this possibilities:
1) Sketch distance (pixels) and a editable value - this part, I think, is understandable but comments on useful values are welcome
2) Optional: Use node reduction (means yes or no)
But what values does the belonging editbox with the title Tolerance except (meaningful values and their effects)
Thank you for help,
André
Thank you for help,
André
I'm guessing the Tolerance relates to Use node reduction, which probably means running the Remove Node command after the draw, but I can't find a description of those parameters either (I would like to be able to customize REDN).
Steve
