Problem in Fractal Terrain 3 with menu Campaign Cartographer Export.
Hello everyone, I have a problem in Fractal Terrain 3 (Version 3.0.1.2). That I can not create a setting according to my settings in the menu "Campaign Cartographer Export" (accessed by the "File -> Save Campaign Cartographer File"), covering the altitude, the climate map etc.. Here is the link from the image menu for clarity:
http://s30.postimg.org/dzlo1huu9/Immagine1.jpg
Once you have set the parameters I enter a name for my "profile":
http://s30.postimg.org/g1m5fqstd/Immagine2.jpg
But it gives me this error:
http://s30.postimg.org/5g2a3qmht/Immagine3.jpg
I tried with various options and various names, but I have always the same error. Even trying to edit existing profiles the program does not save the changes.
    Please try to run FT3 "As administrator". To do so, right-click the FT3 shortcut, choose Properties, and on the Compatibility tab, set "Always run as Administrator". Does that allow you to save your own export settings?
