Un-deletable entity causing zoom issues
                    I am currently experiencing an issue where I end up zoomed to a white screen and have to use Zoom to Text to get out.  I have tracked this issue to something on my 'Walls' sheet, but I cannot get rid of it.  I hide all sheets except the Walls sheet (and the Common one, of course), select the eraser, right-click and select 'All.'  CC3 tells me I have 26 entities selected.  Then I right-click again, select 'Not' and drag over the walls I actually want.  CC3 now tells me I have 1 entity selected.  I right-click again and select 'Do It.'  The eraser command clears, as it is supposed to.  However, if I follow the same steps to select everything in exactly the same way, I still have 26 entities selected.  Which seems odd, so if anyone has any advice that would be appreciated.
Then try your above method again. Once the offending entity is gone, freeze the previously noted layers again.
This should solve your problem.
