Change Map Dimensions
I created a new drawing, not using a template, I picked 350’ by 350’, with a gray background. After I got ½ way through the Map I realized I mis-counted and the map needs to be 370 by 370, but I can’t figure out how to change that. I also would like to change the background color. I have searched the forums, but I can’t figure out how to change the map dimensions or the background fill style. Is there a way to change these settings?
For editing the old Map, make sure all layers are thawed, then use the STRETCH command (Edit > Reshape > Stretch) to move the right border 20 units to the right and the top border 20 units up.
Use Change Properties and select by layer BACKGROUND to change the fill style of the background entity.
Thanks,
When I copy it copies the border and the background tile. I try to freeze the layers to prevent them from being selected, but it does not seem to work.
When I stretch the map, the background tile does not get stretched. I try to edit the properties of the background, but it has no effect. So I can't get either method to work.
When you stretch, make sure the layer "BACKGROUND" is not frozen, and that you DO include the background rectangle in the stretch window.
So when I do a copy freezing the layers does not work, but when I do a stretch it does work?
