Pictures not showing up
I just got CC3, CD3 and DD3 and love them! However, a lot of the symbols and other pictures/textures are showing up. I've tried reinstalling with and without checking the clipart box and can't seem to fix it. On the last reinstall I went in this order: CC3, CC3patch, CD3, CD3 bitmaps, DD3, then the fantasy floorplans pack.
This is what I'm getting when I open up some of the files:
http://www.voidgamers.com/images/data/photo/terrain/scenery/DLMOS-screenshot.jpg
Any advise would be greatly appreciated,
David
    edited September 2008
    Because the patch updates all installed products, the patch should be the last thing you install.
    As for that particular example map, I noticed it uses a lot of fill styles from issue 16 of the Annual (This was the "Example City" issue, which was a preview of what CD3 had to offer). Looks like a normal CD3 install doesn't install these fill styles for you.
    Try the "example 2" file instead. That seems to be made using proper CD3 fill styles. If that looks ok, I think everything is ok with your installation, it's just example 1 that uses Annual fill styles.
    Actually, on a closer look, the "example 1" map IS the actual map from Annual 16, so as long as you don't have the annual, this won't show up properly.
  • Ok, after checking the other maps I think everything is fine. On the plus side it gives me an excuse to pick up the annuals :P
    Picking up the annuals is highly recommended. I love them.
    The Example 1 map is actually using the Annual bitmap fills - a mistake on my part.
    Here is a corrected version.
