Cannot delete layers
As the title says. I select a layer, hide and freeze all other layers, SHOW all Sheets (so no entities are hiding on a hidden sheet), use the erase command to delete everything on the map that is on that layer.
But, after doing so, when I try to delete the layer itself, it says it can't, and pops up an error message box saying the layer "has entities on it" as the reason why it can't delete the layer.
Any idea what's wrong here? Just wanted to delete some layers that I made a while back to test some things, but that I'm no longer using.
Or it is possible that a symbol has an entity on the layer. As the symbol reference will be on a different layer, you can't directly delete or edit these. To fix this, type CS at the command (for Correct Symbols). This should move ALL symbol parts to the SYMBOL DEFINITION layer. Be careful if you are using symbols that need parts on different layers.
So, the obvious conclusion is that you were right Ralf, and there are some of these "hidden" entities, that I can then move to a different layer (if I am correct, I can go Change Layer > right click > Layer > select the layer the hidden entities are on, which will select them so they can be moved). Making a backup of my map is all well and good (thanks for mentioning that sdavies - I always do before messing with anything unknown, but it's good to remind people of this; it can save you from disaster!), but what ARE these entities? What do they do? Could moving them have unexpected effects on anything later? Would like to know if it's possible to determine the answer to those questions first...
