Glow + Transparency = No transparency
Dear All,
I am trying to make an object with a glow transparent. When I do that the transparency does not work. If I turn off the glow the transparency works as expected.
I recreated the problem in a clean map with only a floor and a black circle.
With transparency and NO glow
Kind regards,
Xander
You can reverse the order of your effect, placing the transparency under the glow (from your examples, I guess the transparency is the first effect.)
However, you will still get a neat marked circle area because inside that shape the glow and the circle stack.
I believe the best solution would be to make a bigger circle and use the Edge Fade, Inner effect.
The following one is transparency first then blur... that one is a lot better but there is a sharpish circle edge as you predicted
I'll try playing with edge fade inner as well. The problem is that I want to use it on symbols not just circles. I presented the circle because it is a lot easier to see what happens.
I'll do some more experiments with fades and seperate glow layers for symbols and report back.
Thanks
