Where is the layer manager / draw-order manager?
So I'm getting a bit further with this program and ran into what I hope is just a simple matter of "click here."
Where is the layer manager to control rendering order? I created a map, and when I started dropping mountains, for some reason they dropped underneath the CONTOURS layer in the draw order. I cannot figure out how to easily move layers up and down the draw order. I can figure out how to move sheets up and down to manage the way effects render, but not the vector layers themselves. In other GIS/vector tools such as QGIS/GRASS or ArcGIS, this is done via the 'contents' window that lets you drag/drop layers to rearrange the draw order.
I figured it would be done in the little "L:" info box at the top that lets you select what layer you're working on, but it's not there.
I also tried the "Bring to front/forward" buttons but those didn't do it either - even though I had the RELIEF/CONTOURS layer selected, it wouldn't actually select the contour polygon, it just fumbled around with trying to select the mountain symbols instead (but still didn't put them on top of the CONTOUR layer).
This is super basic geographic vector management stuff, I hope I'm just missing something simple. Help appreciated!
You'll see the drawing sheets listed in the order they are drawn in, meaning the topmost sheet is drawn first and therefore appears behind everything else.
Hope that helps!
But once you have it, it works well. Then you use the layers as logical groupings.
Steve
