Crenalations. Seeking clues, help, advice.
I need some advice on adding crenelations to the tops of these arrow shaped bastions. I've been trying but the results never properly line up.
e2.JPG 55.4K
    Sorry, I''m not sure what you are trying to do. Care to explain a little further? Perhaps post a "failed" attempt?
  • illuminatispyilluminatispy Traveler
    edited June 2014
    Thank's Ralf!
    What I'm trying to do is add crenelations/battlements to the top of these arrow shaped towers.
    I can get them looking okay at point A but at A2 they look wrong. I really want them to match the walls from the castles symbol set at point B. I exploded the symbol for it's crenelations C. No matter what I do I can't get them to the right angles to line up in the correct perspective along the top. The curved walls at points D are even more of a nightmare.
    Getting them to match the walls from the Castles symbol set is the goal.
    By the way, please post images at a reasonable size that can be viewed at a glance here in the forum. I've reduced the size of your images to 800 pixel width, that should be enough.
    Unfortunately the Castles set doesn't have crenelation that would fit these walls out of the box. What I would recommend:
    - Draw the shape of your walls in top down mode (not in isometric view). Perhaps you have them already?
    - Add crenelations in this view as simple rectangles
    - Use the "3d Projection" command to convert this into an isometric view.
    - Use "Extrude" to make the projected rectangles into 3d blocks.
    See the attached image for a simple example.
    edited June 2014
    Thank you Ralf. I had tried a similar approach to that but I see what I did wrong. Your illustration helped and is working. The results look good and will look much better after some detail work.
    I will also remember to keep my images small in the future.
  • Wow - that's pretty badass.
