FT3 Export to CC3 crashes when trying to change contors to bitmap fills.
Is it possible to export from FT3 to CC3 using texture climate setting instead of the solid color fill? Whenever I try to change the fill style of a contour in an exported map CC3 crashes. This happens on both multipolly and non multipolly export options. I want to export a map from FT3 and convert it to the overland satellite style from CA62. Its problematic if I can't change the fills of the contours. If it were possible to export with the texture climate fills I'd only have to move things to different sheets and add effects.
