John Speed Map problem
I am going through the 07 annual and working on the John Speed map format. I cannot figure out how to draw a horizontal wall (i.e. parallel to the horizon). Is this done with one of the tools in the annual, or is just a drawn line with one of the standard tools.
Also, the pdf references the 45d drawing tool it when it first starts talking about placing walls. I cannot visualize how it is suppose to be used.
    edited May 2014
    Select Spd Wall 20' 45dE and hit the up (or down) arrow key on your keyboard.
    That part of the tutorial was a bit confusing to me as well at first. Just chug ahead and place some symbols down (use the up/down arrow keys to get a perpendicular symbol) and you'll see how they should be placed. You will have to draw extra lines to connect some wall segments.
    Here's one I just started.
  • Thats what I needed, thanks!
