Problem saving with pdfcreator (cc3 crashes)
Hi new forum user here,
I want to save my battlemaps as pdf for printing at a copyshop, I installed pdfcreator, but everytime I try to "print" my files CC3 stops working and sometimes if I close the program, the pdfcreator context pops up and i can save a partial pdf of the map.
System is Win7, 8gig RAM, installed as Admin, so should be no problem there, CC3 works otherwise like a charm.
Is there a known solution?
  • Jay_NOLAJay_NOLA Traveler
    What version of pdfcreator are you using? Some users reported problems with the newer versions of it and found that older builds didn't have trouble.
    Try using the older 0.9.6 version of it.
    http://www.filehippo.com/download_pdfcreator/tech/3635/
    Also some PDF conversion programs have had problems for some users due to various reasons while others haven't. Have you tried using a different PDF convertor program?
  • thanks for the answer found the problem it was the old ID-10T or POBCAK problem, I wasn't used to the time it takes to convert with sheets on (without sheets it converts instantly), I just had to wait longer (ra. 5 minutes), now I have another problem but will look for possible answers/solutions first before posting a new thread.
    (problem is, that my A3 maps are split into two A4 pages and if i change the paperformat it makes the map smaller)
