Hex Maps Problems
I'm trying to install the Hex Overland Map from http://www.profantasy.com/annual/2010/july10.html onto my CC3.
But when I click on it it starts then says Cannot open C:\Program Files (x86)ProFantasy\CC3\regadd.bat then it says Cannot open C:\Program Files (x86)\ProFantasy\CC3\System\regadd.reg then says 'some files couldn't get extracted'. What should I do now?
EDIT:
I seem to be able to install it by running as admin, but I can't start a new map in Hex Tiles style... Whenever I try it says 'does not respond', freezes, and shows a black greenish screen... Any ideas? (I seem to be able to run the standard CC3 overland style with minimal problems outside of lag. And I can put a hex symbol into my CC3 standard overland style but I can't start a new map using the Hex Tiles.)
    Windows has a problem with programs installed in C:\Program Files\ that make lots of changes, like making maps. This is probably mentioned on the Profantasy web site, but I had better results installing in C:\Profantasy\CC3\ That folder doesn't exist, but if you put the patch in the nistaller program, it should work.
